Atwater Kent Type L Chassis 1930
Just finished getting this AK 76 Type L TRF chassis working yesterday. I believe it was the last of the AK TRF production. For you AK purists, it was not totally recapped and most of the non wire-wound resistors were way out of spec or open.
Receives stations across the dial and distant/local switch is very effective. Lots of volume with the pp 45s. That's the Type N 12 inch speaker in the background.
Very pretty!!
How was the wiring on the power transformer? Some of those A.K sets used rubber/gutta percha wire on the transformer leads which can perish, fortunately it's easier to replace then may sets since they used terminals inside.
The owner brought me the set with a shorted hv secondary so he decided to buy a donor set on ebay. That set is clean and the power transformer has some deteriorated insulation on the 5v winding leads. Covered it with heat shrink. Also transferred the front panel to the new set because it is in better shape.
Nice job, Rob! The old girl cleaned up nicely. Take care and BE HEALTHY! Gary
Wow Rod, that AK76 sure came a long way technologically for a TRF compared to my AK35! Very nice!
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Ron, yes, the circuitry has bypass and filter capacitors everywhere but has 2 ps chokes, a speaker field coil, no electrolytics. It must weigh 30 lbs, then the speaker is another 20.
I only have 3 AKs, having restored 2 of them; when I hold a chassis in my hands, everythings creams "QUALITEEEEE". They are beautiful. They look like they have just came out from the factory 90 years after they had. Very few radios do.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9537 online users. [Complete List]
» 2 Member(s) | 9535 Guest(s)
