philco model 84
I unhooked wire from the if to grid of second detector and put a 4 meg resistor to ground and a .047 cap and used a second radio to drive the audio amp and there was no distortion. must be from second detector or first detector. some station are and some are not our local station is not distored.
I have -16.5 volts on 42 grid also tried a pm speaker sounds the same 250 volts on screen grid 233 volts on plate of 42
I will work on it somemore Thursday.
Update on distortion after some more voltage checking screen voltage on second detector (77 tube )was 27 volts should be 23 didn't think 4 volts would matter but it did added 440k resistor from screen to ground to lower screen to 23 volts help distortion on most stations.
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4369 online users. [Complete List]
» 1 Member(s) | 4368 Guest(s)
