Philco 42-380 Need Electrolytic Need
Greetings,
New member here.
When I pulled the chassis all the resistors were changed out, and caps. The electrolytics and Bakelite block were not.  .
Schematic calls for 3 electrolytics (1 duel).  There were only two l electrolytics in place, lytic 61 was confirmed and swapped out. I'm confused on the duel electrolytic # 20 and 20a, schmatich doesn't show connections for 20a (?).
Help!   Icon_eek
Welcome to the Phorum! Icon_wave
See https://philcoradio.com/library/download...20Book.pdf
20a is connected to one end of the field coil #59 and ground.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 7952 online users. [Complete List]
» 2 Member(s) | 7950 Guest(s)
