Tube Diagram - XXL
Anyone have a source for the base diagram and pins for an XXL tube?
http://www.nj7p.org/Tube4.php?tube=xxl
Also see the specs for the 7A4 which is identical to the XXL:
http://www.nj7p.org/Tube4.php?tube=7A4
Thanks, Ron. Always appreciate your help.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6674 online users. [Complete List]
» 1 Member(s) | 6673 Guest(s)
