Need Dewald Model J-802 Schematic
Does anyone have a schematic for a DeWald model J-802?  It’s a 7 tube AM/FM radio in a Bakelite case.  The model I have uses a selenium rectifier and has a three wire plug in cord. I have included a couple of images for reference.  Any help would be appreciated.  Thanks.
Chet
Welcome to the Phorum!
Icon_wave
Looks like someone was similarly looking for that on ARF back in 2014 and did not locate one and someone else asked in 2019 also with no luck. They looked at SAMS as well apparently.
Steve Johnson has a few more schematics listed than nostalgiaair but J-802 is not listed. You might contact him anyway just to be sure.
Hopefully someone else on the Phorum can help. Good luck.
Thanks for the quick response. I did try Radio Museum and Nostalgia Air also with no luck. Sometimes manufacturers put a small schematic on the inside wall of the cabinet. I was hoping someone may have this with a similar model. I will follow up with your recommendation. Thanks again.
Chet
Hi and Welcome to the Phorum,
Here's plan B.
We know the set was made in 1955. So we look around other sets that using the same tubes and topography to find something you can use as a guide. Here's a good place to start https://worldradiohistory.com/Beitman-Manual.htm I took a quick scan @ 1955 and a few sets in the RCA and Zenith section that maybe helpful.
Don't get too hung up on the selenium rectifier it's just a resistor & diode vs a tube. Doesn't amount to a hill of beans circuit wise. Move around a bit with the years. I was surprised to see that most of the set listed in '55 AM radios, tube portables, and phonos.
I suppose some manufacturers may have licensed their designs to others during this period and this may be a good source of information. I worked on a Silvertone model recently that I could not find a model specific schematic for but looking at other Silvertone models of the same age was able to find one similar enough to use. I’ll try this route. Thanks for the suggestion.
Chet
My set of rider books stop at 1950, though there may be something in Sams for this set. I could look in the 1955 Beitmans book, which I do have, but it may or may not have Dewald in it.
Could you list the tubes. Thanks David
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9594 online users. [Complete List]
» 1 Member(s) | 9593 Guest(s)
