[split] Philco 7050
Hello!
I'm trying to restore a 7050 that is missing a few things inside. I have the schematic but some good photos of the interior would help a lot. Can you pass me some please? Thank you!
Is the 220 Ohm across the galvanometer ok?
There is no galvanometer and no resistor ?
EDDIE_MUTANTE Wrote:There is no galvanometer and no resistor ?
You are correct - galvanometers are uncalibrated devices with center zero with no current - they are used only to indicate a balance condition when used with an instrument such as a Wheatstone bridge or a laboratory potentiometer. Your 7050 has an ammeter (probably a milliammeter) which is calibrated (however simply) into good and replace zones. That is what has a 220 Ohm shunt resistor across its movement.
Hello Dale.
What I mean (sorry for my horrible English) is that somebody has tryed to use the 7050 for something else and almost all inside has gone.
I have read the instructions to "calibrate" the line and I have rebuild the 6X5GT circuit with one diode and the resistors involved on it. I put one amp meter in parallel with the 220ohm resistor (R107 in the schematic) and connect my varistor regulated at 115Vac (50Hz here). I have 30Vac at the anode and 394 micro amperes. What I'm trying to calculate is the range of the milliamperimeter that uses the the 7050. As the needle must on the center with the meter I think that I need a 1mA amp meter, but will be great that somebody could measure that on a working unit. I have read here that the resistance of that instrument is around 50 ohm, but that don't help me too much.
A greeting!
Eddie -
I hope someone that else can help you because I do not own a 7050.
Thank you very much Dale.
I have poste this in various threats about the 7050 in this forum, I don't know why it have end here.
A greeting!
Well, the modern "analog" meters do use Weston/D'Arsonval galvanometer. To make it into the ammeter a shunt is placed across it, which is why I asked about the shunt resistor.
But the bare system, the magnet, the pivot and the wire frame (coil) with the attached pointer is, well, the Weston galvanometer.
https://phys.libretexts.org/Courses/Geor...nstruments
Looking at the pictures in your "Introduce Yourself" post it appears there is a lot missing from this tester. Perhaps someone here will have one and they can give you a photo of the underside of the chassis.
Hello Eddie -
(My first post so I'm feeling my way through the Phorum process).
My 7050 is currently in disrepair... most notably I obtained it with a non-working meter movement (or as you referenced, a galvanometer).   Multiple pictures are posted of the internals you were looking for.
Since my need is to find a replacement meter I too am in in search of the current rating of the meter for the 7050.   The meter that was inside my unit was severely damaged and am unable to obtain a full scale current reading from it.  All other channels of search have met with a dead end.
Looking for anyone else out there having a Philco 7050 that can help Eddie and me out with this information.
Thanks!
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 6073 online users. [Complete List]
» 2 Member(s) | 6071 Guest(s)
