Philco 42-1012 turntable questions
A friend of my is restoring Philco 42-1012 console. He was looking for some information and I hope you guys can help him:
- what is the diameter of the turntable motor shaft?
- what is the diameter of the rubbered roller, which rotates the disc?
Thank you in advance for your help!
Leonid
Hi Leonid
I am sorry but I cannot answer your questions. I suggest you contact West-Tech Services; they would know the answer.
http://www.west-techservices.com/
Hi Ron,
I know West Tech Services (saw their site at list). But they are not charity, right? Sending the changer to US and then back to Russia would cost my friend a lot of money...
So I hoped there were owners of the same console, who could just measure the diameters.
Leonid
Well, I don't think it would hurt to just ask...
I did have a junk 1942 Beam of Light changer, but I gave it to West-Tech early this year so they could use it for parts.
I do think there are others here who do own 1942 BOL changers; maybe they will add their comments soon.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6803 online users. [Complete List]
» 1 Member(s) | 6802 Guest(s)
