Philco 37-116X Alignment
Hello:
I'm getting ready to make another attempt at aligning my 37-116X manual tuning console. The alignment instructions call for placing a Philco variable condenser (Philco Part No. 45-2325) across the oscillator compensators at various stages during the alignment procedure. Does anyone know how many picafarads this variable condenser is?
William
Me too! I forgot to ask this question in my last post.
John
I think it was 350 pF or so.
But you don't have to use it; the set will align nicely without it.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
