Philco 60 Higher Frequencies
I had this problem once on a 60 after the secondary on the oscillator coil was rewound. Turns out the winding was backwards.
You might try reversing the secondary connections . That's what I did to determine the fault.
Hope this helps.
Well am I surprised. I was so careful to make sure I had wound the coil in the proper direction. I now have reception on the whole AM band. The squealing is gone on the shortwave band too. Nothing on the higher end of the shortwave band except a little noise but it is early in the day. I'll check that tonight. Thanks Ed for the reminder of that. I think I will take the coil out and wind it the other way around so that anyone in the future won't have to wonder about that. I may even tackle that antenna coil wire I described in my last post. I found some pretty good directions on the Phorum about that coil. Thank you Terry for all your help.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 5717 online users. [Complete List]
» 3 Member(s) | 5714 Guest(s)
