Supreme 450 set tester schematic
Iam trying to figure out why these pin sockets are shown as diodes on the schematic. They have continuity.
Did you check them with a low-voltage variable supply to see if they have diode knees?
No, I just used a DMM and checked continuity.
I am not sure diodes were manufactured and used at the time that tester was being built.
Copper-oxide diodes existed at that time. I own a Triplett 1167-A set tester ca. 1935 which uses a small copper-oxide stack as the voltmeter rectifier for measuring AC. I doubt that is what is shown on the schematic, though.
What does this look like. Its soft like a wire and has continuity. Both sides go to the ohms jack.
Current shunt, covered with an asbestos braid tube. Probably a custom value...
Pliny the younger
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 6057 online users. [Complete List]
» 2 Member(s) | 6055 Guest(s)
