37-690 Bass Choke Replacement
While troubleshooting the no bass amplification issue, I think I found the culprit. The choke #104 is reading 164K ohms. My first thought is replace it with a 2K 5W resistor and increase the 1uf electrolytic, just like you would for a speaker, but that parallel 40K resistor threw me. How do I factor that in?
RJ Dial
"Radiodial"
Mendocino, CA
https://philcoradio.com/library/download...201942.pdf
This is the parts catalog.
32-7528 choke is 65H, 10mA, 2,250 Ohm inductance.
Find a suitable one.
Ah, now where to find one.
I've into this before on smaller sets, I now recall. Hammond makes one that is only rated 8MA, and this 37-690 has two stages of bass amplification, so 8ma may be pushing it.
RJ Dial
"Radiodial"
Mendocino, CA
Yes, I just had to deal with that while repairing the 37-604 Philco. Exactly that value choke was gone. And the current was borderline.
So I used a smaller one with larger current, padding it with a resistor.
However, mine was the DC filter, whereas yours is an audio filter, so you need more precision.
Mine was 32-7569, which is same as yours (maybe different dims) - 65H, 10mA.
I used 154E, 2hich is 20H, 20mA.
There is also 30H 600 Ohm one, 157G. Two in series plus a 1k resistor. Those are small chokes too.
https://www.mouser.com/datasheet/2/177/1...736947.pdf
https://www.mouser.com/c/passive-compone...&m=Hammond
Yeah, I know, Mouser and Digikey don't have "big iron" components. For some reason Philco was messing with the 2250 ohms resistance of this common Philco choke by paralleling that 40K resistor. I wish I was smart enough to understand why. Seems to fine tuning it down to 2.1K?
RJ Dial
"Radiodial"
Mendocino, CA
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9831 online users. [Complete List]
» 2 Member(s) | 9829 Guest(s)
