Model 84 correct philco decal
Did anyone ever figure out what philco decal was correct. I read Rons post from years back about using part of one.
Thanks everyone for any help
Bruce
Finally after 50 plus years I'm back into the hobby again. It's like trying to relearn a second language some of it makes sense and some of it doesn't! Could be fun now considering my son is now into old radios and tube technology!
I think it's a PH-8
