Model 70 dial tracking
I recently acquired a Philco Model 70 and have nearly completed the electronic restoration (all bakelite caps & general cleaning) It's working very well (other than sometimes the oscillator needing a jolt to get it oscillating).
However, when I align the dial to 1100 (local station) stations up and down from that point don't line up to where they should be. Before tinkering anymore I thought to ask here on the forum if anyone has any ideas how to adjust the tracking. (They whole band is slightly to narrow).
