"RadioBar" unit with Philco 37-610 chassis
Hello: I have just acquired a gorgeous Philco "RadioBar" unit. It has a 37-610 chassis and works great. I'm replacing the dial scale, as the original is yellowed beyond easy reading. I have always wanted one of these Depression era radios - now I have one. It makes a great conversation piece in our home.......Phil
Sounds like a great acquisition. Enjoy!
