Need the 37-640 Speaker cone dimensions
Hi,
I need to recone my speaker it seems to have a double coil. I was wondering if anyone had the proper dimensions so I can order a kit for it? So far from what I can see, I have 6 1/2", by 1" voice coil opening, but am I measuring right? And I'm not sure about the depth.
I sourced a cone with a store on the net but he said that the depth is very critical.
If anyone has the exact measurements for this type of speaker I would appreciate the info.
Any help or information that can educate me on this would be greatly appreciated.
Thanks!!
I would send it out for repair, but being from canada the ressources are very limited to non existent from what I can see.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
