Swapping IF cans
I have a 46-1226 code 122 that has a bad 1st IF can, part number 32-4106. I was wondering if I coulkd swap it out with a 1st IF from a 41-285, part number 32-4282? The primary and secondary resistances are kinda close but the big problem would be how close the trimmers in the primary are to each other.
Don't think it would be a problem if they are the same frequency and will physically fit the old mounting.
The IF of both the 41-285 and 46-1226 are 455 kc, so I don't see why the swap wouldn't work... Icon_smile
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 3416 online users. [Complete List]
» 1 Member(s) | 3415 Guest(s)
