Philco 90 question
Hi,
I'm working on a Philco 90 chassis with 1-47 output tube. I've checked the tubes, replaced the e-caps and one condenser. The radio does not play however when I grab the cap lead to the 1st detector (24A) it starts playing. If I let go it stops. Any ideas on what I should check next?
Thanks in advance for any help.
Open coil (or coils) in the front end. Very common.
Just use your ohmeter to check continuity on them.
Chuck
Philco 89 indicator light.
There are currently 9258 online users. [Complete List]
» 1 Member(s) | 9257 Guest(s)
