Philco 80/551 GOLD FINIALS FOUND
Moderator, not sure if you consider this an AD ???
I just purchased 6 of the GOLD FINIALS from Ed Shultz of Renovated radios.
Glad to find them being re-produced again.
Bob T
There are currently 10443 online users. [Complete List]
» 2 Member(s) | 10441 Guest(s)
