Philco 84B
I just purchased a Philco 84B. It plays and tunes well. After 10 minutes, it will not tune and makes a high pitch squeal as the tuner is adjusted. Is this a part overheatingand what part might it be?
Thanks for any assistance.
Hard to say which part is at fault. I would poke around the detector circuit. Have any of the caps or resistors been replaced? Have a look at the 1 meg screen resistor and it's bypass cap. Also switch the 77 tubes.
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 4375 online users. [Complete List]
» 2 Member(s) | 4373 Guest(s)
