Philco BC Resistor Wattage
Currently working on a Philco model 620. Have Riders schematic from Nostalgia Air. This BC resistor is #70 on the schematic Philco part# 33-3037 a 2 section 22ohm and 235ohm resistor. Does anyone have info on the wattage needed when replacing? Thanks, Ken
Hi Ken and Welcome to the phourm.
I would think a 25w unit should work fine.
Thanks Terry for the info. Don't think I have that high a wattage in my parts for the ohms I need. Can get it at work. Ken
Wish I worked at your place!
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 4496 online users. [Complete List]
» 2 Member(s) | 4494 Guest(s)
