Veneer Question
Does anyone know what kind of veneer would be comparable replacement for a Model 40-190 cabinet. I am very new to this and was looking at a few sites that sell veneer but there are so many different kinds that I am not sure where I should be focusing my attention. Anyone with ideas? Thanks!
Hi,
Send Phorum member Steve Davis a PM. He can probably tell you exactly what you should use. I know it was walnut, but I do not know exactly which species of walnut was used.
There are currently 9690 online users. [Complete List]
» 1 Member(s) | 9689 Guest(s)
