Source for rebuilding / replacing phono cartridges
I've been dealing with Gib @ West-Tech for my phono cartridge rebuilding needs, but for the last 4-5 weeks ,I've been unable to contact Gib !!! Does anybody have other sources for this service or a place to get replacement cartridges for the 40's and 50's changers ! [I've tried the "Needle Doctor" with no success on my recent needs ] !! Thanks, Lee Petrie, Joliet, Il.
