Output Meter?
I was reading the alignment procedure for a model 48-482 radio, an output meter is to be hooked up to the #3 ant. terminal for aligning. What is an output meter?
Bill
As I recall, that is simply a connection to the speaker (af xfmr secondary) and you can use an AC VTVM just as you would normally. They just put it in a more convenient location so that you don't have to tap into the spkr wiring.
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 4721 online users. [Complete List]
» 1 Member(s) | 4720 Guest(s)
