As Promised: Companion for 84B
I just figured out how to work my replacement camera from CL. A smaller LCD than my broken Kodak, but easier to figure out. A Sony DSC-W230 if anyone is curious.
I couldn't resist this local pick-up even though the style is what I would normally run screaming from. But since it's a radio...
[Image: http://i150.photobucket.com/albums/s92/u...C07369.jpg]
So now when you get hungry, you can help yourself to some cookies from your neat new "radio" cookie jar while you enjoy listening to your Philco 84B! Icon_wink
I don't think I've ever seen one in that style before.
You need to hunt up a "Philco Cookbook" cookie recipe.
Chuck
Hunt successful.
[Image: http://i150.photobucket.com/albums/s92/u...FG2583.jpg]
Boy the robo-ads sure are getting sophisticated. The instant I uploaded this pic to photobucket, an ad with voice and pics for Philly Cooking Creme popped up on their page.
Enough to make you toss your Philcos. We hear you.
