got a line on a 19x or 91x for $25 ..worth it??
i found a set that looks to b a 19x or 91x........for $25........whats it worth restored and not in restored but good condition??......is it worth the restore?.....i know seems rare production ....and people obviously don't know anything about them.....parts available??
Gotta be less than a a dinner fo 2 at McD plus gas. Skip a meal and get it .,
$25 is a giveaway price for a 91X or a 19X. Get it...fast...before it's gone! Icon_arrow
Give it a proper restoration and you will have a treasure.
i am anxiously awaiting an email back.....if they still have it ....i will be picking it up.....they have another set also.....i will probably just pick up both of them .....will let you know what comes out of it......
There are currently 9501 online users. [Complete List]
» 2 Member(s) | 9499 Guest(s)
