Philco 38-15 radio repair help needed
My Dad gave me this radio that he purchased in 1937. It works, sort of. The on/off volume control has one volume, low. I would like to replace it. The part # is L-500M 304715. Are these available? The metal cap on the 6A7 tube is loose and I have found ample suppliers of tubes. I thought I would go as far as I can to see if I can improve the functioning of the radio, and failing that, would take it to a local repair shop (4 are listed in the Dallas/Fort Worth area). What kind of antenna connects to the two wires coming from the rear of the radio? I assume these wires are for the short wave. The AM radio works but not everytime I turn the radio on Icon_confused: , but when it does, it has a hum to it. Any suggestions or ideas are greatly appreciated. I am obviously a newbie, but am open to influence.
Your volume pot/switch is readily available. The on/off + pots are very cheap from RadioDaze.com. You should be able to use their 500K audio taper pot with the added switch option. I always cut the shaft length and cut the flat with a Dremel cutting wheel after installation. Wait for others to add more options to the pot search.
Simply running a "bead" of super-glue around the base of your 6A7 grid cap will hold it very well. When hardened just scrape off any excess with a knife.
A 10' length of antenna is the absolute minimum for broadcast reception; if you have aluminum siding or aluminum faced insulation, you will need to put your antenna out a window and into a tree. 30-60 feet is a good range for shortwave use. Your hum might just go away with a good antenna. If your hum is really nasty, the filter caps will need changing (it's a good practice to change them anyway).
Pete AI2V
I forgot to make mention of it the other day, but last week I corrected another error on my schematic (applies to both R...jrblasde — 09:27 PM
Gloritone 27 Radio
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM
Gloritone 27 Radio
Hello john, That, is the first time I have have seen or heard of that brand and model. Welcome to the party !! Sincer...radiorich — 08:08 AM
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27: A little bit of extra t...Eliot Ness — 05:48 AM
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM
There are currently 1561 online users. [Complete List]
» 1 Member(s) | 1560 Guest(s)
