Philco 80 Jr, just starting....
#31
(03-21-2012, 07:07 PM)7estatdef Wrote:  Actually the grid leak is the 3 or 4 meg resistor in the grid circuit.
Oh, 4M in parallel to 50pf cap to the grid, yes. No, I don't want to change it - it can be easily measured and gives me 4.4M reading which is within reason.
And the cap is probably also mica.
The speaker table error?
Philco 70 antenna lead
