philco radio
hello all
my uncle has this philco radio and i'm trying to gather all the info i can about it. i think ive got it matched up to the model 40-165K that's in the photo gallery if anyone could confirm that from the photo below.
most likely he'll sell it but i'm trying to get all the info on it first, it in really good shape, it lights up and you can hear static but its not receiving.
[Image: http://img84.imageshack.us/img84/2491/mo...65k.th.jpg]
thank you
chris
Yup, 40-165K.
http://www.philcoradio.com/gallery/1940a.htm#ab
There are currently 9731 online users. [Complete List]
» 1 Member(s) | 9730 Guest(s)
