46-420 Code 125 Replacing Cap with wire coil
I am in the process of recapping this "Hippo" and ran across this cap with wire coiled around it. It is an original Philco cap stamped with .2mfd 400 wv.
Here is a picture of the cap.
Can I use just a regular .22 mf mylar cap to replace and what do I do about the coil?
Thanks- this is my first post here so I hope I did this correctly,
Frank
Hi,
We've been discussing this same part in this thread:
http://philcoradio.com/phorum/showthread.php?tid=3609
Hopefully this will help you as well.
Thanks Ron, I may try just replacing with .22 leaving the coil off and see if it creates any problems. If it does I'll have an idea what might be causing them.
Frank
The speaker table error?
Philco 70 antenna lead
