RCA 128 capacitor question
Hi All,
I'm currently restoring my RCA 128. this is a set I have wanted for many years and it's a beautiful radio, but I'm finding out that it's a major pain in my lower regions to recap!! Icon_crazy Caps are buried everywhere in this set!!!! Anyway There is a 4MFD 25V. electrolytic in the circuit. Thing is- I have all the needed caps on hand and don't want to have to order just this one special. my question is- can I just install a 4MFD 500V electrolytic in it's place? I have some of these on hand. The value is the same, just the working voltage is way out there. Anyone have any input? Thanks!
Kevin
Hello, Kevin: I feel your pain, as I had to do some extensive work on my 128 that had supposedly been electronically reconditioned by someone's "technician."
Yes, you can ALWAYS replace a cap with one that has a higher voltage rating. Personally, I only order 450V electrolytics to be able to cover most applications, and 630V film caps for .001mFd-.68mFd values.
TA Forbes Wrote:Hello, Kevin: I feel your pain, as I had to do some extensive work on my 128 that had supposedly been electronically reconditioned by someone's "technician."
Thanks for your input! I was pretty sure it would be okay. Just didn't know if the large difference in working voltages would affect anything.
Kevin
Eico 232 VTVM Schematic
There are currently 6883 online users. [Complete List]
» 1 Member(s) | 6882 Guest(s)
