Model 46-1213 Record Changer M-4 Substitute
I am hip deep in the restoration of the 46-1213 and have a question regarding the changer. It is a Model M-4, operating at 78RPM. My question is is there a later unit that can be substituted that operates by 33 and 78 RPM. Such as shame to just have 78, while I have many 78's, many more 33's.
Thanks and Happy Halloween.
The speaker table error?
Philco 70 antenna lead
There are currently 6007 online users. [Complete List]
» 1 Member(s) | 6006 Guest(s)
