In-Line Fuses
Question from the new guy,
I would like to know what value is appropriate for the fuse ? Amps and voltage, I think I read somewhere that it should be a fast-acting/blow fuse. It's for my Philco 37-630. Just about finished the recap and resistors.....
Kurt
Fast acting fuse is not necessary. They are intended mainly for semiconductor protection. Use a normal blow with the standard 250V rating. Current rating from 1 to 2 amps is good for most situations.
Usually the power consumption is given on schematic and the current can be calculated with ohms law. 140 watt radio plugged into 120V mains is 140/120 gives 1.16 amps. A 1-1/2 amp to 2 amp fuse is Ok.
Richard
I don't even know why a power line fuse is necessary unless you have a lot of lightening strikes or power surges in your area, even in sets with failed power transformers it's usually the high voltage secondary that has failed not the primary, I would be more inclined to fuse the center tap of the high voltage winding. There is a guy on you tube that even installs fuses in AC/DC radios, and with big ugly 20 amp fuse holders, with pig tails, designed for cars, a complete waste of time since the cathode of the rectifier tube already serves that purpose.
Yes, I tested them out of the circuits. I posted my measurements where the first letter was red and the second was blac...R3Sons — 08:52 PM
1. Have you tested out of circuit? 2. If yes, any transistor not showing E-C as OL is bad. From your measurements, all...morzh — 08:27 PM
42-345 Resistors
In short (I a sure you've seen the video Rich provided), safety caps are X and Y. X caps are placed across the Line/Neu...morzh — 08:21 PM
Restoring Philco 96
Today I decided to take on gutting the big bad cap block. I gave up on the same one from the 86 before, so I was not sur...morzh — 08:13 PM
42-345 Resistors
To not replace is to put it on the list to do later when they cook up! As a radio guy would say back in the day, lets sp...Paul Philco322 — 07:19 PM
Here's the readings from the AR14 (No markings on the one from the 5TPO) on the 6TPZ: B-E OL E-B .14 B-C 2.9 C-B .13...R3Sons — 04:17 PM
Thank you all so much. First the power supply: "KORAD KA3005P - Programmable Precision Variable Adjustable 30V, 5A...R3Sons — 03:48 PM
Perhaps I am missing something - which volume (AR-28 or AR-33) has the 6TPZ?DaleHCook — 12:16 PM
1950 Emerson TV resurrection attempt
:lol: Ya got that right Mike! I watched it some last night for a couple hours and it seemed pretty stable. Not bad for a...TV MAN — 11:05 AM
Is your power supply adequate? Perhaps it cannot source the current required. Or...bad transistors.morzh — 09:32 AM
There are currently 3023 online users. [Complete List]
» 2 Member(s) | 3021 Guest(s)
