(Lack of) tracking on 41-255
I have one of these radios. It sounds great and works fine using the pushbuttons on the AMBCB. However, all the tunable bands act like they are bandspread tuning. If I set the LO to be spot on at 1400 KHz, tuning down the dial, I get about 10-15 KHz for every 200-300 KHz I go down the dial. I've looked and looked at the schematic, but for some reason I'm just not seeing it. There must be some significant series L or C that's keeping it from tracking properly. It's also off in a similar way on the SW bands.
If anyone has any experience with this particular problem, I would appreciate any help you can give.
TIA
Brenda Ann
On the osc section of the tuning condenser does the rotor and stator have the same number of plates? Was thinking maybe someone pulled some of the rotor plates out. Short of that perhaps a mechanical problem, the dial is moving faster than the cap.
Everything mechanical is sound and functioning properly. Tuner is complete, it just acts more like a trimmer, like there's a series capacitance to ground that's not right, but the schematic shows no such capacitance.
Hi Brenda,
Double-check to confirm that the LO is actually functioning in the non-PB mode by monitoring its frequency.
-Bill
Probably wouldn't hurt to give the P/B and bandswitch a good cleaning.
Eureka! The problem ended up being a well-disguised broken ground strap from the tuner to the chassis. I should have gotten a clue earlier when I noted that getting my hand or a tool anywhere near the tuner caused frequency changes, but one doesn't think of broken ground braids..
It tracks a lot better now, but still won't drop in perfectly. It's up to 20 KHz off in the middle of the AMBCB if I align it to be spot on at 600 and 1440 (and it's way off at the top: 1600 comes in at 1660).
Time to repeat the alignment procedure from the top. Assume the padders have been cleaned out, dried and restored to approximately the original positons for a start. Old trick, count turns in, disassemble, clean, dry, assemble, turns out for a start.
The speaker table error?
Philco 70 antenna lead
There are currently 6808 online users. [Complete List]
» 1 Member(s) | 6807 Guest(s)
