Info on model N-1880-124?
Hi Philco Pholks,
I have this large Philco cabinet and I don't know much about it. Apparently it's a model 1880 and, from what little I've found on the WWW, was made around 1964. Can anyone here tell me more about it?
Thanks!
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
I can add that this set is actually a 1965 Model year set.
The N prefix in the model number denotes this.
Chuck
Philco 91 Tuning Condenser
There are currently 3631 online users. [Complete List]
» 1 Member(s) | 3630 Guest(s)
