Take a look! Model 144B Cathedral
Now that's stunning. Very nice!
I was frankly surprised to see this old thread brought back with more comments.
Allen in SB Wrote:I have a question regarding the "acorn" knobs. The replacement parts list includes three knobs - a Knob (Large), a Knob (Small), and a Knob (Station Selector). I've seen large and small acorn knobs. Do you know the difference between these and the station selector knob?
Sorry for not answering sooner, Allen -
The tuning knob needs to have a set screw to hold it in place, as it uses the same tuning mechanism as the 44 and the 5-band 16 - the tuning shaft pulls out to provide slow-speed tuning, and then pushes in to provide fast-speed tuning. You can't pull the shaft out if the knob does not have a set screw to hold it in place.
Yup, the lower center knob on my 144 should be a large hex knob. Oops. Icon_crazy
The large tuning knob on my set is a reproduction, with a set screw to hold it in place and allow for the two-speed tuning mechanism to be used.
WOW !!!! Icon_clap Whoever did the refinish did an outstanding job !!!! Looks like it just rolled off of the assembly line. Another beauty Ron !!!! Alan
Philco 91 Tuning Condenser
There are currently 5290 online users. [Complete List]
» 1 Member(s) | 5289 Guest(s)
