1951 Shure cartridge replacement catalog in PDF
This is a link to download a PDF of the 1951 Shure phono cartridge replacement catalog. It's 4.2Mb in size. Lots of good cartridge info.
http://shure.custhelp.com/ci/fattach/get...cement.pdf
Larry
Great info, thanks for the link!
There are currently 9838 online users. [Complete List]
» 2 Member(s) | 9836 Guest(s)
