Stromberg Carlson Osc. Coil Question?
In the Want Ads on this forum I posted a pic of an osc. coil out of a Stromberg Carlson 145L that I need. You may have seen it. Pretty cooked. I may have found a replacement but it's out of a SC model 160. It appears as if the 160 has an extra band. Here's the schematics. 145 is first. In your opinions will the 160 part work in the 145L?
http://www.nostalgiaair.org/PagesByModel...021358.pdf
http://www.nostalgiaair.org/PagesByModel...029931.pdf
Pepper
"It's Nice To Be Nice To The Nice"
Major Frank Burns Mash 4077th
There are currently 9915 online users. [Complete List]
» 1 Member(s) | 9914 Guest(s)
