Found inside a homebrew
Along with 2 other books was this 1934 Philco radio log. Even has a listing in for listening to Admiral Byrds 2nd Antarctic expedition.
[Image: http://i248.photobucket.com/albums/gg187...w001-1.jpg]
Cool!
Neat!Icon_thumbup
Philco 91 Tuning Condenser
There are currently 4421 online users. [Complete List]
» 1 Member(s) | 4420 Guest(s)
