How do I get my Philco 16X to tune?
Guys I am dying on this... Here are some pics I posted on ARF:
http://antiqueradios.com/forums/viewtopi...1&t=199544
Anyhow can get my 16 to tune using the knob, I did the small o-rings, not sure how the big dial turns them...
Thanks for any response!
Try this link:
http://www.philcoradio.com/tech/drive.htm
Philco 91 Tuning Condenser
There are currently 5336 online users. [Complete List]
» 1 Member(s) | 5335 Guest(s)
