41-95 cap
This arrived the same day as the 611B but survived the trip. USPS on this one versus UPS made a difference?
When I removed the chassis there was a 0.25 Philco cap in there. It was connected to ground and to one of the tubes. According to the schematic I have there is no such cap there. There was only one 0.05 cap present and the schematic calls for two. Was this a change Philco made post production or is the wrong size cap there?
thanks
Chris
You're correct Chris - there is no part at 0.25 uF. in the 41-95. Since the surviving end is connected to ground, the only two caps it could be are #11 and #12. Both are 0.05 uF @200V. as the Parts List shows.
The only other caps to ground are #10, the electrolytic on the B+ line and $8 a mica cap. The unlabeld cap on the 2nd. IFT shown in the schematic is internal to the IF can and is probably a mica as well.
Just use the schematic to check the connections to these two caps to discover which it is.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 6775 online users. [Complete List]
» 2 Member(s) | 6773 Guest(s)
