Help identifying movie radio
I have seen an interesting old radio in two 1950's movies, any idea
what it is?
Located in the bookcase of the Psychiatrists office in the movie
"The Three Faces of Eve"
Same radio is playing in the grocery store where the gigantic ant attacks
in the movie: "THEM"
There are currently 9746 online users. [Complete List]
» 2 Member(s) | 9744 Guest(s)
