Philco 38-3 console
Hi guys and gals, Just wanted to ask a question to see if anyone has a working Philco 38-3 console out there. I am able to pick one up this weekend , and if anyone could tell me how good a performer this radio is would be a help. I already have a 38-116 that I am very,very happy with.I just love those old Philco's. Thanks for the info!
It's a decent nine-tube set. Not as good as your 116, but still pretty good.
If it's worth it to you, grab it!
Philco 91 Tuning Condenser
There are currently 5382 online users. [Complete List]
» 1 Member(s) | 5381 Guest(s)
