Schematic for a 14B - Never mind
Does anybody have a clear schematic for a 14B?
It's done.
Thanks
I'll bet Chuck does. I need to get one too. The one on NA really bad. From the looks of it it ought to be a great playing set. One rf amp, two if amps, and three stages of audio... Plus a shadowgraph. I've got the 14 modern version.
I'm about 3/4 of the way through this one now. by the time I find a ledgable schematic, I won't need it. I'll let you know in the morning how well it works.
Interesting that a lot of the dogbone resistors in this one seem to have drifted down rather than up, or they were lower to start with and did not drift (much).
Yes, a 42 driving 2 more in PP. Should be loud, anyway.
Yes, Phlogiston, I have an original Model 14 Service Bulletin No. 176, in my archives,
and all published Production Change Notes from Philco. Shadow Meter info as well.
Regards,
Chuck
Thanks guys, but it is all done, just takes a couple of hrs longer without a good schematic. It is hard to tell which contacts are used in the Bakelite caps without one.
It is a very nice radio. Picked up lots of stations with only a 18" antenna.
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
There are currently 3938 online users. [Complete List]
» 2 Member(s) | 3936 Guest(s)
