Philco Not Restored as Indicated in Ad
After working a couple hours I'm still not there but it's definitely better. I got it away from the work bench where I have way too many other wires going here and yon and it sounds better in another room but, from about 775 on the dial down to the lowest frequency there's a severe motor boating, popping and squealing. I checked the dial position at a better and stronger station, along about 900 and it was coming in at 850 on the other radio. Looks like an alignment is necessary. Problem is I don't have a signal generator. From 850-1500 I pulled in lots of stations but below around 850 it's terrible. Any suggestions? I've replaced all paper caps, electrolytics and several suspect resistors. I measured the value of the other resistors and they were within spec or just a touch higher.
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 8320 online users. [Complete List]
» 2 Member(s) | 8318 Guest(s)
