Zenith 6D-815
I have a Zenith Model 6D-815 that came out of my sister's estate and as I was looking it over I noticed the electrolytics were replaced at some point as were all other capacitors. I discovered two of the tubes weren't up to snuff after checking them out in my EICO 625 and replaced them.
It has a real scratchy volume and stations weren't very perceptible...only a few and the volume control was stiff. I sprayed contact cleaner in it and it's still stiff but I can get 4-5 stations but not all that clear due to the sound of eggs frying, particularly between stations.The volume acts like it wants to go up but doesn't unless you purposely turn it up. It's like something's not making contact somewhere. There were no burned resistors Anything else to look for?
Probably the elecrolytics need to be replaced as a bare minimum. I would not power it up again until this is done. If the paper capacitors haven't been replaced, I would do 'em all, and probably all the carbon resistors as well, as it will only be pennies apiece and should be done all at once. Also I would apply a tiny amount of WD40 to each switch and control bushing, and give all contacts and control innards a nice spray with Deoxit 5, and let dry overnight. I'd probably clean out tube sockets and pins with a little Deoxit on a pipe cleaner, and check for firm contact with tube pins. Could also be dust or whatever on Tuning Capacitor, and a blast to Deoxit usually does it, but if there is a lot, a piece of paper can usually dislodge it. Be patient, this takes a few moments.
Let us know.
It was the electrolytics. Apparently they don't last as I long as I thought. These couldn't be more than about 10 years. I don't have any De-Oxit so,I sprayed the tuning capacitor first, then I had already sprayed the volume control but squirted a little WD-40 on the outside of the control. I need to swap out the tube contacts. Being a pipe smoker, I have plenty of pipe stem cleaners. Thanks for the suggestions. An alignment probably wouldn't hurt either.
Well, rats. The folks at Moyer have already confirmed that they do not have any of this model of IF transformer in stock...jrblasde — 08:00 PM
What should I offer?
I am curious, as I have seen those names before. Where did the nicknames of Sheraton and Hepplewhite come from?jrblasde — 05:26 PM
The only ones I am getting from the 1940-s, if ever, are the 1948 Sheraton or Hepplewhite. Not interested in the rest.morzh — 05:22 PM
See above. Try to see about the shorted caps etc, remove the transistors, and do not populate them until you rectify t...morzh — 05:04 PM
I swore one console was enough, but now I see a nice looking 47-1227 down in Muskogee!  :lol: I am trying to resist the ...jrblasde — 05:03 PM
The consensus is $50, which is what I was thinking. I've sworn off repairing phonos , but what's one more? Thanks for ...nocusr — 04:56 PM
Alrighty. I'm back. I'm not ready to give up. Suggestions on where to start?R3Sons — 04:54 PM
Well, in the declining years folks sometimes tend to use what disposable income they have left to pamper themselves to t...morzh — 04:51 PM
Yeah Mike I figured him to be late 70s. Looked like he lived alone as thete was only seating for one person in the room ...462ron — 04:14 PM
I think you have a chance at purchasing a 48-1286, based on the cabinet hardware. Only 8700 were produced, so it is a r...GarySP — 02:28 PM
There are currently 2246 online users. [Complete List]
» 3 Member(s) | 2243 Guest(s)
