Philco 91RX field coil.
Hello,
I an helping a friend restore his Philco 91RX code 122 and I need to know the value of the field coil resistance. I can't find it anywhere on the service sheets.
Thanks in advance.
Stuart
The RX should have two speakers in the remote cabinet, an H7 and a K12.
H7 field coil is 3275 ohms
K12 field coil is 3275 ohms.
Hello Mr Forbes,
Thank you very much for that.
Regards,
Stuart
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 9804 online users. [Complete List]
» 2 Member(s) | 9802 Guest(s)
