Aligning a 37-116X
I just finished re-capping my 37-116X manual tuning set. All went well and everything seems to function. I am getting ready to align the radio and this is my question. Should the alignment be performed with or without the speaker connected. The instructions don't say. Thanks for your reply.
William
WITH. The speaker field coil is part of the power supply. With this set be sure to follow the Philco alignment instructions to the letter.
There are currently 8721 online users. [Complete List]
» 4 Member(s) | 8717 Guest(s)
AvatarAvatarAvatarAvatar
