Saw a 39-80 Over the Weekend
It was in poor condition, no grill cloth, bad finish decay, chipping veneer, broken dial glass, etc. when I was picking up a Truetone D1952 console I had bought.
What caught my eye (other than the very small chassis/very tall cabinet with inclined dial board) was what appears to be AM and longwave only dial coverage.
http://www.philcoradio.com/gallery/1939a.htm#ae
Anyone familiar with this one? Sorry no photos, didn't have the time or a camera handy.
More on the non-Philco radio later.
Mike
P.S.
Found out a little more about it today. Looks like this was a farm style battery powered console. Strange, but that fits for where I saw it. No interest in it and it showed up on CL today it looks like:
http://greensboro.craigslist.org/ele/3638604095.html
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
That's not longwave, it's the AM band in meters wavelength.
Brenda,
Thanks for the clarification. I should have figured that out rather than glanced at it. First time I can recall seeing that feature.
Mike
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
There are currently 9582 online users. [Complete List]
» 2 Member(s) | 9580 Guest(s)
