RCA 810T tuning belt
Does anyone know the procedure on how to access the tuning belt and replacement on this type of RCA radio. Need help.[Image: http://i1281.photobucket.com/albums/a508...1cc58f.jpg]
Wow lucky you I have been looking to purchase a RCA 10 tuber for such a long time. Sorry I can not help you out on your tuning belt question. Some one will answer your question...Come on guys give a reply. Good luck on the radio its a really good set!
I kinda remember, from 30 years ago, that you have to pull the pointers and remove the dial scale.
Then again, I can't remember what I had for lunch...
John
Las Vegas, NV USA
