Philco 37-660 speaker
Will a speaker from a philco 37-660 fit and work in a philco 36-645K ? Are the same speaker.
No. The 37-660 speaker has a field coil resistance of 2200 ohms, while the field in the 645's original speaker (H-21, by the way) has a field of only 435 ohms.
Here are speakers that would work in your 645K:
H-21 - 97H, 97D, 97X, 640X
H-26 - 37-650X, 37-650PX, 37-665X, 37-2650X - 460 ohm field, close enough
H-30 - 37-9, 37-10, 37-11 - 480 ohm field, close enough
Thanks Ron looks like I have a bad field coil and I'm searching for a replacement.
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2963 online users. [Complete List]
» 4 Member(s) | 2959 Guest(s)
AvatarAvatarAvatarAvatar
